nesta
Nov 11, 2013Aspirant
ReadyNAS Duo
New here....just got this box and I'm trying to reset it so I can 1. get access to the web interface and update the firmware 2. reset it to default, so that it can show up on my network for access...
nesta
mdgm wrote: ??????
My article indicates that means you have a v1 hardware revision 2 not a v2.
If you have a v2 it would say "ReadyNAS Duo v2" on the front.
To do a factory default.
1. Power down the unit
2. Press and hold the reset button
3. Power on the unit
4. The disk LEDs will blink once at 5 seconds and again after 30 seconds. Release the reset button after the second blink (about 30 seconds).
Thanks a lot for the clarification. I'd have to re-download the right firmware. Where can I find that link, please help.
I've done what you said here and now the power LED is fading in and out and all disks, plus backup are flashing...should I just wait.
