nesta
Nov 11, 2013Aspirant
ReadyNAS Duo
New here....just got this box and I'm trying to reset it so I can 1. get access to the web interface and update the firmware 2. reset it to default, so that it can show up on my network for access...
mdgm-ntgr
Nov 11, 2013NETGEAR Employee Retired
RAIDiator 4.1.12
Though if you open Frontview, switch to Advanced Control and go to System > Update > Remote and click Check for Update the NAS will check for a firmware update and you can download it directly to the NAS. No need to browse for a download link.
Since this is a new setup after doing the firmware update (requires reboot) and verifying it completed successfully I would suggest doing another factory default via System > Update > Factory Default to get a clean setup on 4.1.12.
