nesta
Nov 11, 2013Aspirant
ReadyNAS Duo
New here....just got this box and I'm trying to reset it so I can 1. get access to the web interface and update the firmware 2. reset it to default, so that it can show up on my network for access...
nesta
mdgm wrote: RAIDiator 4.1.12
Though if you open Frontview, switch to Advanced Control and go to System > Update > Remote and click Check for Update the NAS will check for a firmware update and you can download it directly to the NAS. No need to browse for a download link.
Since this is a new setup after doing the firmware update (requires reboot) and verifying it completed successfully I would suggest doing another factory default via System > Update > Factory Default to get a clean setup on 4.1.12.
Thanks a lot.
I will do this.
It's currently updating from 4.10 to the latest, which perhaps it what you've listed here.
Now the fun stuff....can someone please direct me to them. I can't wait!
