BySteve
Jan 01, 2022Aspirant
ReadyNAS Essentially Denial of Service
Something happens to the RN214 where it becomes so busy that I essentially suffer a denial of service. I do not see anything that I am causing to run, like a back up. This is the second time it has h...
Jan 01, 2022Guru - Experienced User
Have you tried downloading the log zip right after the problem clears? The logs might have some clues.
Also, if ssh is enabled, you could see that is taking the resources from the linux CLI.
BySteve
Jan 02, 2022Aspirant
Thanks for the reply and happy new year! Unfortunately, the log says nothing!
