elaux402
Jan 27, 2017Aspirant
ReadyNAS failed power suppply
I have a failed power supply that I am trying to replace. The model on the old power supply is ST-220FUB-05E. When I look up this model number I keep finding power supplies that will fit physically b...
bedlam1
Jan 27, 2017Prodigy
According to an Amazon offering for that part no. the PSU autosenses 110 or 220VAC
Also if you look here http://www.seventeam.com.tw/product_contentx.php?theme_select=1english&pid=146&cid=186
you will see that the minimum amps 12 VDC are 1 , the nominal are 7 amps and the maximum are 14 amps
If you replace like for like i.e. Seventeam ST-220FUB-05E I feel confident you will be fine
Which NAS model is it for?
