jdemoccc's avatar
jdemoccc
ReadyNas Hard drive Serial Number
Does anyone know if there is anyway to determine the serial number of a hard drive inside a Netgear ReadyNas remotely? I am not onsite but i am trying to determine if the hard drive is still under warranty? I can see the serial number of the ReadyNas unit but i do not think the hard drives were bought with the unit but rather seperately.
Thanks
Joe
  • On the NV+ v1 go to Status > Health and look at the SMART stats for the disks. You'll see the disk serial numbers. You could alternatively download the logs and look in there.
    Welcome to the Community!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    • jdemoccc's avatar
      jdemoccc
      Health only showed the model number but in the logs i found the serial number. thanks
        mdgm-ntgr
        On the NV+ v1 there is a SMART+ button under Status > Health for each disk. Clicking on that would lead to a popular window opening showing the disk model, serial and SMART stats.
ProSupport for Business
