utelme
Oct 23, 2017Aspirant
ReadyNAS Hardware Performance
Hello, Currently have a ReadyNAS 4 bay model 314 is has 2 Western Digital 4T drives and 2 Western Digital 6T drives installed I have been trying to increase the perfromance of this device i.e re...
utelme
I took the drives to the retail for testing and they came back good. Though 2 of the wentern digial 4T drives were not rated for NAS they were greens, but they all tested good. The service clerk claims it might be the machine that is causing the error and hence the preformace indicator showing decrease. She Claims this is common with Netgear ReadyNAS and that I might need to replace it. I have a screen shot of read/write stress tests using a Mac app called Blackmagicdesgin Disk Tester. Here is the results
My issue is when I copy transfer data in large sizes i.e. 100Gig's vs say a small file around 800megs the smaller file seems to take forever to copy go figur.
additionally an issue that came to mind was the use of Netgears propriatory X-Raid, though they
state it's the best choice offering reducdancy I cannot retrieve data using any other brad of NAS. Would it not
to switch to Flex Raid and chose Raid 5 so I can access data from a competitors NAS.
Oct 23, 2017Guru - Experienced User
First of all, XRAID isn't all that proprietary - it is built on a standard software RAID tool called mdadm. In your case, the disks are mixed sizes. XRAID creates a 4x4TB RAID-5 layer, and a 2x2TB RAID-1 layer to take the extra space on the 6 TB drives. The btrfs file system spans both of those layers. Moving to RAID-5 wouldn't get any more space - all it would do is reduce your storage by 2 TB (since two TB of the 6 TB drives would be wasted).
Secondly, your speed graph shows 100+ MB/sec for reads and writes in the dials at the top. That is limited by your gigabit network connection, not the NAS. I don't know exactly what is being tested with the video profiles underneath - or whether the units for read/write there are megabits per second, frames per second, or something else. But my guess is frames per second, since the 4K numbers are about 4x slower than the 1080p numbers (and 4K images have 4x the number of pixels).
It is true that all NAS perform fastest on large file transfers. But 800 MBs is still a large file. Can you tell us how long it takes to read and write an 800 MB file to the NAS?
Also, what disk drive is in the Mac? The transfers can't go faster than your Mac drive.
Do you have disk spindown enable in the NAS or on the Mac?
To get the absolute fastest performance from your NAS, you'd want to use enterprise-class disks in all slots (WDC Red Pro or WDC Gold). Or SSDs - though that likely doesn't make sense, given your file sizes. I don't recommend using Green or Desktop drives, but I don't know if replacing your green drives with NAS-purposed drives like WDC Reds would improve the small file transfer performance or not.
Not to my knowledge (and I think I know more about it than she does). She likely wants to sell you something. Netgear does make faster NAS (yours is at the bottom of the business-class products, and was recently replaced with an RN400 series). But if you are already getting 100 MB/s speeds, then you won't get much faster performance on 800 MB+ files with any NAS unless you also deploy a new network (10 gigabit instead of 1 gigabit).
