tigerten
Apr 27, 2023Luminary
ReadyNAS internal flash/USB
What is the internal USB and/or flash structure? How does the boot process work? Here is what read from small net builder review abut 626x : 256 MB USB module with Phison USB 3.0 controller and Tos...
Sandshark
Apr 28, 2023Sensei
The ReadyNAS used syslinux for booting, and the syslinux boot data is on the flash. But in normal mode, that boot sends it to the OS partition of the drives for the actual booting. Other modes either put an image from flash into RAM and boot that or boot a USB device. The flash also contains a default OS image used for an OS re-install. In the case of a legacy device, the flash also includes the vpd file, which identifies your NAS type and serial number. None of your personal or configuration data is stored in flash -- it's all on the drives.
