shafy
Jun 29, 2021Aspirant
ReadyNAS keep refreshing
My Ready Nas pro seems not wotking properly. The pages keeps refreshing and logging back in again and again, Then my PLex is not working.. I cant even uninstall or reinstall. Please can you help ...
Sandshark
Jun 29, 2021Sensei
Is your Pro4 running OS6, and did you recently update to 6.10.5? If so, there are at least a dozen posts on this already. Please do a search.
If that's not it, then you'll need to be a bit more specific about what you are seeing.
- shafyJun 30, 2021AspirantI update the readynas 1 month ago to the latest version. It was all working fine. Suddenly the issue of refreshing happens. Plex is not working. So if I go to Plex a d try to remove it, the page start to reload. See attached (connecting to readynas ) and it will not remove. Even If I try to update the Plex it's the same.
I tried reinstall the OS as well. But no luck.
Tried lowering the the OS version. But no luck.- SandsharkJun 30, 2021Sensei
So you did update to 6.10.5? Then search the forum for one of the other message chains regarding the login issue instead of expecting your duplicate question to get a duplicate answer. Google does a better job of searching than the forum's own search engine, BTW.
As for the Plex issue, you probably need to get the other issue resolved before anyone can help you. It's unclear whether or not it's related.
- shafyJul 01, 2021AspirantI was searching all and trying those solution. But no luck.
