stretchjr
Aug 29, 2012Aspirant
Readynas maintenance
Jedi, Hopefully one last question for the day. I habitually blow the dust and other things out of my NAS about every 6 months. Basically I label my drives, pull them out and blow out the chassi...
PapaBear1
Aug 29, 2012Apprentice
If you remove the PSU, you will void the warranty on the unit. The next time you take the side and top panels off to blow out the dust, you can remove the upper panel with the fan (carefully unplug the 3 pin fan power lead). This will expose the back plane printed circuit board and you will be able to see the top of the PSU under it. You can then direct the nozzle of the canned air down in that gap and blow out the dust forward without removing the "do not remove" sticker covering one of the PSU screws.
