Cliff_MI
Nov 10, 2021Guide
ReadyNAS Management services offline
I have a ReadyNAS 3100 that is off line. I can't get into it at all. It refuses SSH. The Webpage hangs up and does not load.
I have tried a OS reload, but I don't think that worked. It is running 6.10.2.
It is not now responding to any CIFS request.
Does anyone have any idea how to get it back on line. I don't want to do a factory reset since I am not sure of of the quality of the backups I have on it. This is at a business.
My next idea is to remove the disk and use an old disk and try to update it and then restore the disks and see what happens.
I hope that would fix it.
These are the diagnostic reports I can pull with RAIDar
- 2021-11-10 18:36:22: rndb_import() ==> 3 (606ms)
- 2021-11-10 18:36:22: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:22: dba import failed
- 2021-11-10 18:36:22: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:21: rndb_import() ==> 3 (586ms)
- 2021-11-10 18:36:21: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:21: dba import failed
- 2021-11-10 18:36:21: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:21: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:21: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:21: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:21: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:21: rndb_account_import() ==> 3 (325ms)
- 2021-11-10 18:36:20: rndb_import() ==> 3 (665ms)
- 2021-11-10 18:36:20: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:20: dba import failed
- 2021-11-10 18:36:20: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:20: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:20: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:20: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:20: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:20: rndb_account_import() ==> 3 (322ms)
- 2021-11-10 18:36:19: rndb_import() ==> 3 (667ms)
- 2021-11-10 18:36:19: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:19: dba import failed
- 2021-11-10 18:36:19: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:19: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:19: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:19: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:19: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:19: rndb_account_import() ==> 3 (330ms)
- 2021-11-10 18:36:18: rndb_import() ==> 3 (653ms)
- 2021-11-10 18:36:18: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:18: dba import failed
- 2021-11-10 18:36:18: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:18: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:18: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:18: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:18: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:18: rndb_account_import() ==> 3 (317ms)
- 2021-11-10 18:36:17: rndb_import() ==> 3 (599ms)
- 2021-11-10 18:36:17: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:17: dba import failed
- 2021-11-10 18:36:17: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:17: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:17: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:17: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:17: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:17: rndb_account_import() ==> 3 (313ms)
- 2021-11-10 18:36:16: rndb_import() ==> 3 (711ms)
- 2021-11-10 18:36:16: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:16: dba import failed
- 2021-11-10 18:36:16: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:16: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:16: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:16: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:16: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:16: rndb_account_import() ==> 3 (295ms)
- 2021-11-10 18:36:15: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:15: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:15: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:15: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:15: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:15: rndb_account_import() ==> 3 (299ms)
- 2021-11-10 18:36:14: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:14: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:14: rndb_account_import() ==> 3 (1023ms)
- 2021-11-10 18:36:13: Failed to insert into $timemachine_quota table
- 2021-11-10 18:36:13: _rndb_update_timemachine_user() ==> 3 (0ms)
- 2021-11-10 18:36:13: rndb_account_import() ==> 3 (4785ms)
- 2021-11-10 18:36:13: rndb_import() ==> 3 (5309ms)
- 2021-11-10 18:36:13: Error rndb_import() ==> rc=3
- 2021-11-10 18:36:13: dba import failed
- 2021-11-10 18:36:13: Failed to start ReadyNAS System Daemon.
- 2021-11-10 18:36:13: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:13: DB (queue) schema version: new ==> 0
- 2021-11-10 18:36:08: DB (main) schema version: 24 ==> 24
- 2021-11-10 18:36:08: DB (queue) schema version: new ==> 0
other errors from the logs.
Nov 10 18:13:38 southbackup sshd[3344]: pam_winbind(sshd:auth): getting password (0x00000000)
Nov 10 18:13:38 southbackup sshd[3344]: pam_winbind(sshd:auth): request wbcLogonUser failed: WBC_ERR_AUTH_ERROR, PAM error: PAM_AUTHINFO_UNAVAIL (9), NTSTATUS: NT_STATUS_NO_LOGON_SERVERS, Error message was: No logon servers are currently available to service the logon request.
Nov 10 18:13:38 southbackup sshd[3344]: pam_winbind(sshd:auth): internal module error (retval = PAM_AUTHINFO_UNAVAIL(9), user = 'admin')
Nov 10 18:13:38 southbackup sshd[3344]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=10.10.10.75 user=admin
Nov 10 18:13:47 southbackup sshd[3355]: pam_winbind(sshd:auth): getting password (0x00000000)
Nov 10 18:13:47 southbackup sshd[3355]: pam_winbind(sshd:auth): request wbcLogonUser failed: WBC_ERR_AUTH_ERROR, PAM error: PAM_AUTHINFO_UNAVAIL (9), NTSTATUS: NT_STATUS_NO_LOGON_SERVERS, Error message was: No logon servers are currently available to service the logon request.
Nov 10 18:13:47 southbackup sshd[3355]: pam_winbind(sshd:auth): internal module error (retval = PAM_AUTHINFO_UNAVAIL(9), user = 'admin')
Nov 10 18:13:47 southbackup sshd[3355]: pam_winbind(sshd:account): valid_user: wbcGetpwnam gave WBC_ERR_DOMAIN_NOT_FOUND
Nov 10 18:13:47 southbackup sshd[3355]: pam_unix(sshd:session): session opened for user admin by (uid=0)
Nov 10 18:13:53 southbackup sshd[3355]: pam_unix(sshd:session): session closed for user admin
Nov 10 18:13:55 southbackup sshd[3362]: pam_winbind(sshd:auth): getting password (0x00000000)
Nov 10 18:13:55 southbackup sshd[3362]: pam_winbind(sshd:auth): request wbcLogonUser failed: WBC_ERR_AUTH_ERROR, PAM error: PAM_AUTHINFO_UNAVAIL (9), NTSTATUS: NT_STATUS_NO_LOGON_SERVERS, Error message was: No logon servers are currently available to service the logon request.
Nov 10 18:13:55 southbackup sshd[3362]: pam_winbind(sshd:auth): internal module error (retval = PAM_AUTHINFO_UNAVAIL(9), user = 'admin')
Nov 10 18:13:55 southbackup sshd[3362]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=10.10.10.75 user=admin
Nov 10 18:14:03 southbackup sshd[3369]: pam_winbind(sshd:auth): getting password (0x00000000)
Nov 10 18:14:03 southbackup sshd[3369]: pam_winbind(sshd:auth): request wbcLogonUser failed: WBC_ERR_AUTH_ERROR, PAM error: PAM_AUTHINFO_UNAVAIL (9), NTSTATUS: NT_STATUS_NO_LOGON_SERVERS, Error message was: No logon servers are currently available to service the logon request.
Nov 10 18:14:03 southbackup sshd[3369]: pam_winbind(sshd:auth): internal module error (retval = PAM_AUTHINFO_UNAVAIL(9), user = 'admin')
Nov 10 18:14:03 southbackup sshd[3369]: pam_winbind(sshd:account): valid_user: wbcGetpwnam gave WBC_ERR_DOMAIN_NOT_FOUND
Nov 10 18:14:03 southbackup sshd[3369]: pam_unix(sshd:session): session opened for user admin by (uid=0)
Nov 10 18:14:09 southbackup sshd[3369]: pam_unix(sshd:session): session closed for user admin
Nov 10 18:17:01 southbackup CRON[3737]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 10 18:17:01 southbackup CRON[3737]: pam_unix(cron:session): session closed for user root
Thanks for any help
- mdgmVirtuoso
If you can download the logs zip the first thing to check would be how full the 4GB root volume is. A full 4GB root volume can lead to the management service failing to start.
Then there's other things like the main services configuration file etc.
Failure to insert the time machine quota table could possibly point to a data volume issue, I guess, which would be more serious.
- Cliff_MIGuide
Good to hear from you again.
I was able to pull the log file, But I don't know what file I am needing to look into.
Biggest issue is that I can't get into the device at all. ssh rejects connections. I did an os reload which reset the password and IP information. But I still can't get into see what might be filling the machine or what might have gotten corrupted.
Do you have any suggestions?
Thanks
- Cliff_MIGuide
i see this error in the readynasd.log
Nov 10 18:12:07 southbackup readynasd[2963]: readynasd log started
Nov 10 18:12:08 southbackup readynasd[2963]: readynasd started. (restarted=0)
Nov 10 18:12:09 southbackup readynasd[2963]: Error rndb_import() ==> rc=3
Nov 10 18:12:09 southbackup readynasd[2963]: dba import failed
Nov 10 18:12:10 southbackup readynasd[3030]: readynasd log started
Nov 10 18:12:10 southbackup readynasd[3030]: readynasd started. (restarted=0)
Nov 10 18:12:12 southbackup readynasd[3030]: Error rndb_import() ==> rc=3
Nov 10 18:12:12 southbackup readynasd[3030]: dba import failed
Nov 10 18:12:12 southbackup readynasd[3094]: readynasd log started
Nov 10 18:12:12 southbackup readynasd[3094]: readynasd started. (restarted=0)
Nov 10 18:12:13 southbackup readynasd[3094]: Error rndb_import() ==> rc=3
Nov 10 18:12:13 southbackup readynasd[3094]: dba import failed
Nov 10 18:12:13 southbackup readynasd[3151]: readynasd log started
Nov 10 18:12:13 southbackup readynasd[3151]: readynasd started. (restarted=0)
Nov 10 18:12:14 southbackup readynasd[3151]: Error rndb_import() ==> rc=3
Nov 10 18:12:14 southbackup readynasd[3151]: dba import failed
Nov 10 18:12:14 southbackup readynasd[3208]: readynasd log started
Nov 10 18:12:14 southbackup readynasd[3208]: readynasd started. (restarted=0)
Nov 10 18:12:15 southbackup readynasd[3208]: Error rndb_import() ==> rc=3
Nov 10 18:12:15 southbackup readynasd[3208]: dba import failedNot sure what that means.
- SandsharkSensei
Have you received any messages regarding a full or nearly full OS partition? How full is /dev/md0 showing in the === df -h === section (near the bottom) of volume.log?
- Jun 10, 2022Retired_Member
