jtaylor1
Aug 15, 2014Aspirant
ReadyNas NetGear failing and needing a reboot
We order countless readynas backup devices and ship them out to our customers. They fail so often that we have created a script to E-mail us when they fail. We then have to call our customer and reboo...
mdgm-ntgr
Aug 15, 2014NETGEAR Employee Retired
If the problem is a full OS partition you should configure email scripts that alert you to the issue so you can deal with the problem proactively before it becomes a problem.
e.g. an email with output from
Could configure a script to only send it if the usage is over a certain level. Then look into the system, find out why it is getting so full and take steps to reduce the likelihood of that happening again. While you are it update the firmware on the box if it is out of date.
# cat /var/log/raidiator_version
# df -h
# df -i
