Retired_Member
Jul 08, 2015ReadyNAS NIC bonding compatible with Cisco SG200 Switch?
I setup 802.3ad LACP bonding on my Neatgear ReadyNAS box. The bottleneck is now my router since I only have 1Gig ports on the back and can't setup bonding on my router. If I get this Cisco Switch (...
Jul 08, 2015Guru - Experienced User
What system are you trying to transfer the files to? Does that system also support LACP?
I don't know about the SG200 (I have a GS724Tv3 from Netgear).
LACP can increase speeds if you have multiple data flows (for instance multiple users). But each data flow is still limited to 1 gbit.
