Retired_Member
Jul 08, 2015ReadyNAS NIC bonding compatible with Cisco SG200 Switch?
I setup 802.3ad LACP bonding on my Neatgear ReadyNAS box. The bottleneck is now my router since I only have 1Gig ports on the back and can't setup bonding on my router. If I get this Cisco Switch (...
Jul 08, 2015Guru - Experienced User
And LACP is not designed to do that, unless you have multiple file transfers happening at the same time (and perhaps not even then). See page 7 here: http://www.ieee802.org/3/hssg/public/ap ... 1_0407.pdf
PowerMan572 wrote: With everything connected and setup as 802.3ad LACP (NIC bonding) I want to accomplish closer to 2Gigabit speeds vs. 1Gig.
Maybe try MLB first, since that doesn't require you to buy a switch. And its possible that MLB will increase your speed.
If you do buy the switch, use the "layer 3+4" xmit hash in the NAS (and the switch if it has it).
