DerekSW
Jul 03, 2020Follower
ReadyNAS not booting after firmware update to 6.10.3
After updating to 6.10.3 my device doesn`t boot. I allready tried tot shutdown fot 10 minutes and the boot again. I have network connection but can`t connect to the admin panel. The device is dete...
Jul 03, 2020Guru - Experienced User
Do you have a backup of your data?
One option is to
- first try an OS reinstall
- then if that fails try a USB recovery
If you can boot into tech support mode, then you could also use paid netgear support (my.netgear.com).
