sjschmidtky1
Aug 20, 2020Guide
ReadyNAS NV+ - External Drive Not Recognized
I bought a new Seagate 5TB external drive for backup of my ReadyNAS. I originally attached it and formatted it FAT32 from the NAS, but it didn't recognize the full 5TB. So, I formated it NTFS on my...
Sandshark
Aug 20, 2020Sensei
The NV+ can only handle drives with GPT formatting, which has a max size of 2TiB. That's closer to 100% of the 3TB drive, so maybe you aren't noticing it there.
sjschmidtky1
Aug 20, 2020Guide
What is GPT formatting?
The current drive that works is showing:
File System: NTFS
Used: 2487 GB
So, it appears that it indeed does support a larger size, right?
Steve
- SandsharkAug 20, 2020Sensei
GPT is is a partition type, below the level of the file system. It stands for GUID Partition Table. It was introduced to overcome the 2TiB limitation of the MBR (Master Boot Record) partiton method. The normal limit for MBR partitions is 2TiB (about 2.2TB), and your working drive does seem to have more space than that, for which I have no explanation.
- StephenBAug 20, 2020Guru - Experienced User
What firmware are you running on the NAS? 4.1.x or 5.3.x?
- sjschmidtky1Aug 20, 2020Guide
Running 4.1.16 What does that conclude about my situation?
