UrbanLarsson
Feb 09, 2022Aspirant
Readynas NV+ (4.1.16) Can't access frontview any more, security issue
Hi! After windiows update I Can'ät access my frontview any more, both edge and chrome says: err_ssl_version_or_cipher_mismatch Please advice! Urban
JeraldM
Feb 09, 2022NETGEAR Employee Retired
Welcome to the community!
Have you also tried Internet Explorer and Firefox?
If it's still the same issue, please try using an older version of any web browser.
JeraldM
NETGEAR Community Team
UrbanLarsson
I’ve tried chrome and now edge.
Chrome worked yesterday so it must be some kind of update of windows?
Works in Opera, it just gives the same warning that Chrome use to do.
My hope is that i can disable some security setting and go back to use Chrome.
Its my private network on a VLAN so the security isnt something i worries about
- caciavarFeb 09, 2022Aspirant
I just started experiencing this issue today, not with a Netgear product specifically, but with sites that don't have a valid SSL certificate, and the issue is with Chrome v98. The Chrome update happened automatically, but after going back to Chrome v97, everything works fine again.
- ET2661Mar 01, 2022Aspirant
Same problem anyone have any other fixes ? Since limiting chrome versions isn't a long term answer and all the usual browsers don't work either.
- StephenBMar 02, 2022Guru - Experienced User
ET2661 wrote:
Same problem anyone have any other fixes ? Since limiting chrome versions isn't a long term answer and all the usual browsers don't work either.FWIW, you can use internet explorer, as does IE mode with Edge. No idea how long that will be the case.
rnxtras.com has add-ons to install TLS 1.2 for 4.2.x and 5.3.x systems - but not 4.1.x. I provided some guidance on how to reconfigure 4.1.x NAS to prevent https redirection (which allows http access to Frontview in any browser). More info in the link below.
