webit
May 29, 2018Aspirant
ReadyNAS NV+ accessing in a window 10 enviroment
Hi,
I have been diving into knowledge base and searced for a solution where the ReadyNAS NV+ could be accessed like in win 7 - So far I dont see any solution - Can you smart folks help us out
- May 29, 2018
There are two answers that work, and both need to be done on the Windows system.
- enable the SMB 1.0/CIFS client or
- enable the NFS client (and enable NFS on your NAS shares)
So look in "turn windows features on or off) for those two features. Both have similar security implications.
You might also need to add NAS credentials into the Windows Credential Manager, since Microsoft is locking down guest access.
May 29, 2018Guru - Experienced User
