X2PBC
Nov 12, 2014Aspirant
ReadyNas NV Dead #24190256
Hi I have a ReadyNAS unit that has done many years of service, but now it seems the power supply is dead. I assume there is nothing else it could be? So how do I move the disks into another u...
vandermerwe
Nov 12, 2014Master
No you cannot just move the disks.
If you buy a new readynas with enough bays to hold your disks, then I believe Netgear support will help you to migrate you disks to the new unit. You will need a separate device(s) to backup all the data on the disks during this process.
