X2PBC
Nov 12, 2014Aspirant
ReadyNas NV Dead #24190256
Hi I have a ReadyNAS unit that has done many years of service, but now it seems the power supply is dead. I assume there is nothing else it could be? So how do I move the disks into another u...
vandermerwe
Nov 12, 2014Master
No.
If you buy a new readynas ( 104,314,316,516) then Netgear will help you.
They would need you to put your existing disks into the new enclosure, then they would get you to transfer the data onto USB disks or another nas, then you would be able to setup the new nas and restore the data.
You will not be able to do this yourself.
