X2PBC
Nov 12, 2014Aspirant
ReadyNas NV Dead #24190256
Hi I have a ReadyNAS unit that has done many years of service, but now it seems the power supply is dead. I assume there is nothing else it could be? So how do I move the disks into another u...
Nov 12, 2014Guru - Experienced User
mdgm is also suggesting that you could use multiple backup drives (e.g, two 3 TB USB drives). IMO you need a backup capability anyway. You can of course re-use your old drives, though if they are not on the HCL Netgear will deny support.
The NV+ v2 is also end-of-life, you'd want to get an OS6 unit (RN100, RN300, RN500, ...)
Another option for the transfer is to jury-rig a temporary PSU for the NV+.
