SimonM1
Mar 13, 2015Aspirant
ReadyNAS NV+ Died - Recover Data? #24845419
Hi, I've got a ReadyNAS NV+ (RND4000v3) which I had to power down to move last night. It shut down normally (or so it appeared), but now will not power on. I suspect it's a PSU failure but can't be...
mdgm-ntgr
Mar 13, 2015NETGEAR Employee Retired
You have a NV+ v1 hardware revision 3: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
For recovering data using the 314 you would need some assistance as the RAID format we use on the 314 is different. You could open a support case. Depending on the state of your array and volume there may be a charge for the recovery attempt.
Do you recall whether you were using X-RAID or Flex-RAID?
Your NV+ disks could be migrated to another v1, but not to a v2.
