SimonM1
Mar 13, 2015Aspirant
ReadyNAS NV+ Died - Recover Data? #24845419
Hi, I've got a ReadyNAS NV+ (RND4000v3) which I had to power down to move last night. It shut down normally (or so it appeared), but now will not power on. I suspect it's a PSU failure but can't be...
mdgm-ntgr
Mar 13, 2015NETGEAR Employee Retired
The NV+ v1 hardware revision 1, NV+ v1 hardware revision 2 and NV+ hardware revision 3 have only minor hardware differences between them.
The NV+ v2 is a completely different product.
Best in my view to put a spare disk (not from your array) in the replacement, make sure the firmware is at least as new as what you were running (and if not upgrade, then verify the update is successful), then power down, remove the spare disk and migrate your disks across.
