Flockhammer
Apr 04, 2020Tutor
ReadyNAS NV+ Frontview loads to home screen but nothing happens when I click any options.
So i have an issue where I cant get anyof my options to load on the FrontView page no matter what browser I use. Chrome, Firefox, Edge, IE, and Opera. I can login to the admin page no issue and the h...
- Jun 09, 2020
I was able to get this sworted out. It ended up being a subnet issue on my network. Once I was able to get everything on the same subnet the admin page started working as it should. Thanks for the help.
Apr 05, 2020Guru - Experienced User
Flash isn't used, so that's not a factor. You might try using incognito mode in Chrome and see if that works.
Have you tried rebooting the NAS?
Also, what firmware are you running?
- FlockhammerApr 07, 2020Tutor
Same issue when using incognito mode in Chrome.
Firmware: RAIDiator 4.1.16 [1.00a043]
- StephenBApr 07, 2020Guru - Experienced User
It is working with my own NAS (also running 4.1.16) using Chrome as the browser.
Something is definitely wrong. Do you have a backup of the data? Is ssh enabled on the NAS?
- FlockhammerJun 09, 2020Tutor
