Flockhammer
Apr 04, 2020Tutor
ReadyNAS NV+ Frontview loads to home screen but nothing happens when I click any options.
So i have an issue where I cant get anyof my options to load on the FrontView page no matter what browser I use. Chrome, Firefox, Edge, IE, and Opera. I can login to the admin page no issue and the h...
- Jun 09, 2020
I was able to get this sworted out. It ended up being a subnet issue on my network. Once I was able to get everything on the same subnet the admin page started working as it should. Thanks for the help.
Apr 05, 2020Guru - Experienced User
Flash isn't used, so that's not a factor. You might try using incognito mode in Chrome and see if that works.
Have you tried rebooting the NAS?
Also, what firmware are you running?
Flockhammer
Apr 07, 2020Tutor
Same issue when using incognito mode in Chrome.
Firmware: RAIDiator 4.1.16 [1.00a043]
- StephenBApr 07, 2020Guru - Experienced User
It is working with my own NAS (also running 4.1.16) using Chrome as the browser.
Something is definitely wrong. Do you have a backup of the data? Is ssh enabled on the NAS?
- FlockhammerJun 09, 2020Tutor
