paul_j_ghosh
Mar 21, 2012Aspirant
readynas nv+ green disk LED no longer lights up
One of the green disk LED no longer lights up on a readynas NV+. What are my options? Disk is fine and present in that slot.
mdgm-ntgr
Mar 21, 2012NETGEAR Employee Retired
What's the disk_smart log like for that drive? Please post the full log for that drive (omitting the drive serial number). The 2012_03_18 one should be fine (or the last one before you removed and readded the drive)
The NAS runs short SMART tests daily and on boot. SMART won't always detect a problem disk. Testing the drive using SeaTools running both the short and long tests would be the way to go.
