paul_j_ghosh
Mar 21, 2012Aspirant
readynas nv+ green disk LED no longer lights up
One of the green disk LED no longer lights up on a readynas NV+. What are my options? Disk is fine and present in that slot.
PapaBear1
Mar 23, 2012Apprentice
It is best to test the drive while it is connected directly to the motherboard of a PC. Most of the testing applications will not work fully on a drive connected via an enclosure connected to USB.
Another question that was asked but I have not seen an answer to is what are the indicators like when you open RAIDar? In the column for disks you should have 4 indicators and the ones for each installed drive should be green.
