paul_j_ghosh
Mar 21, 2012Aspirant
readynas nv+ green disk LED no longer lights up
One of the green disk LED no longer lights up on a readynas NV+. What are my options? Disk is fine and present in that slot.
crezzlin
May 07, 2012Aspirant
Hi did you ever manage to fix the led fault or just ram, I also have this problem with a V2 version,, it was lighting all 4 drives now just 3 but the drives are fine.. If you did ram di you get a replacement unit and if so did you just put the old drives back in and it worked or did you need to start again..thanks
