eriklundh
Aug 24, 2008Aspirant
ReadyNAS NV+ "half-bricked" by apt-get update+install
in short: anonymous shares are acessible from Windows, but no webbased admin of readyNAS or SSH access. Both port 80 and port 22 is dead. I own two readyNAS NV+ I have installed the ssh and apt-ad...
remcoros
Oct 04, 2011Aspirant
Wow,
I just got to this point in my console:
The following packages have been kept back:
cupsys exim libc-client2002edebian libcupsys2 libldap2 libstdc++5 madplay msmtp nis raidtools2 sysvinit
The following packages will be upgraded:
acl adduser attr base-files base-passwd cracklib2 cron debianutils diff dpkg ethtool file fileutils findutils grep gzip hostname
hotplug ifplugd ifupdown klogd libacl1 libattr1 libcap1 libdaemon0 libdb1-compat libdb2 libdvdread3 libgcc1 libgdbmg1 libgmp3
libident libiw27 liblockfile1 libmad0 libmagic1 libmcrypt4 libwrap0 libxslt1 libxslt1.1 login logrotate lvm-common mailx make mawk
mime-support mlock ncftp ncurses-base ncurses-bin net-tools netbase netkit-inetd ntpdate portmap psmisc shellutils sudo sysklogd
tar tcpd textutils timeout unzip wireless-tools
66 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
Need to get 8650kB of archives.
After unpacking 3494kB disk space will be freed.
Do you want to continue? [Y/n]
I guessss i'll will answer with a big N.
It helps reading forums before doing crazy stuff, thanks guys.
