eriklundh
Aug 24, 2008Aspirant
ReadyNAS NV+ "half-bricked" by apt-get update+install
in short: anonymous shares are acessible from Windows, but no webbased admin of readyNAS or SSH access. Both port 80 and port 22 is dead. I own two readyNAS NV+ I have installed the ssh and apt-ad...
yoh-dah
Oct 05, 2011Guide
remcoros wrote: Do you want to continue? [Y/n]
I guessss i'll will answer with a big N.
It helps reading forums before doing crazy stuff, thanks guys.
Yes, don't do crazy stuff like this -- remember, with root shell access, you're pretty much on your own, and if you want to experiment, make sure you've got your data backed up, and you're willing to spend time restoring your ReadyNAS.
