eriklundh
Aug 24, 2008Aspirant
ReadyNAS NV+ "half-bricked" by apt-get update+install
in short: anonymous shares are acessible from Windows, but no webbased admin of readyNAS or SSH access. Both port 80 and port 22 is dead. I own two readyNAS NV+ I have installed the ssh and apt-ad...
brogahn
Dec 11, 2013Aspirant
I managed to do the same thing. However when the users/groups were being deleted the update stated that the files were renamed to /etc/passwd.org and etc/group.org. I booted to the telnet option (hold the power button for 15 seconds when you power the nas on, and then connect using the tech support mode credentials.
you can the mount the first drive
I used this
mount /dev/hdc1 /loopfs
changed to the loopfs/etc directory
mv group group.new
mv group.org group
mv passwd passwd.new
mv passwd.org passwd.
I then rebooted and was able to access frontview fine and it appears to be running faster.
I used this
mv group group.new
mv group.org group
