eriklundh
Aug 24, 2008Aspirant
ReadyNAS NV+ "half-bricked" by apt-get update+install
in short: anonymous shares are acessible from Windows, but no webbased admin of readyNAS or SSH access. Both port 80 and port 22 is dead. I own two readyNAS NV+ I have installed the ssh and apt-ad...
chirpa
Dec 11, 2013Luminary
Be careful with that. Without X-RAID started, disk 1 partition 1 may be out of sync with the other disks. If disk 1 fails and it has to be recovered from the other disks, your changes may be lost. X-RAID on the Sparc systems is run at a low level, the kernel is not fully aware of it.
I don't have the X-RAID commands, but with enough searching, they can be found in the init scripts.
