sarumbear
Mar 18, 2018Aspirant
ReadyNAS NV+ lost share
Hello I am looking for a solution to find a share that is lost on ReadyNAS NV+ (ReadyNas model no: RND-4B | Product no: RND4000-200EUS). Nethear shows the device is older than 5 years old and no ...
sarumbear
Mar 19, 2018Aspirant
- You can access the NAS "C" volume over SMB using NAS admin credentials, and look for the missing folder from Windows
I did access from Windows using unit's IP address but the share/folder is not showing
- You can use ssh to gain access to the linux shell, and then look for the missing folder via the linux command line.
Can I ask a link to guide me? Also, what credentials I should use?
- You can connect the disks to a Windows PC and use data recovery software (for instance ReclaiMe).
This a 4 disk reduntant RAID array. How do I have to attach the disk to a PC, which disk?
Thank you for your help.
Mar 19, 2018Guru - Experienced User
Again, you need to use the NAS admin account credentials. For instance, run CMD and enter
net use * /delete
net use t: \\nas-ip-address\C /user:admin nas-admin-password
Be careful on the typing (both spaces and the slash directions). The first command ends any open network sessions, if it asks you to confirm you need to allow it to proceed. The second maps the full NAS data volume to drive letter T.
Note that if you use the option above you won't need this.
Download Enable Root SSH Access from https://kb.netgear.com/24586/RAIDiator-5-3-Add-ons. Get Putty.exe from here: https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Use Putty to connect to the NAS IP address with ssh. Use root for the logon, with the NAS admin password.
You need to connect at least three of the disks, and preferably all four. You can use normal SATA in a desktop PC, or you can use a USB dock. Windows won't recognize the disk format, but the RAID recovery software will. Don't allow Windows to initialize or format them.
- sarumbearMar 22, 2018Aspirant
Many thanks for the advice so far. May I ask you to comment on the periferal issue that I explained as such.
"I've also notice that the USB disk share is still showing in the shared list named the same, it is empty and I cannot delete the share. It looks like when removing/deleting the USB disk share something went wrong and NAS lost the plot."
- mdgm-ntgrMar 22, 2018NETGEAR Employee Retired
If you reconnect the USB disk then disconnect it safely, does that resolve that?
