achatter01
Feb 15, 2017Aspirant
ReadyNAS NV+ power supply
I have a ReadyNAS NV+ that I purchased long back 2007/2008 timeframe. It has worked excellently thus far, but yesterday I powered down from the admin panel and today when I tried to power up, it is s...
achatter01
Feb 16, 2017Aspirant
Created an online support ticket (28073258). Hopefully someone from the Netgear team will address soon.
Thanks!
- The_Good_EdFeb 19, 2017Tutor
I suffered a PSU failure in my NV+ a couple of years ago. Netgear support thankfully had replacements in stock. Was an easy replacement - these older boxes are built like tanks!
Best of luck...
- mdgm-ntgrFeb 22, 2017NETGEAR Employee Retired
Thanks!
Can't see any case with that number. Also you didn't specify the serial number when registering your NV+.
- achatter01Feb 22, 2017Aspirant
The S/N was added under a different email ID which I don't use anymore. So when I tried creating the case, it wouldn't let me add the S/N to the case. Any suggestions on how I can add it to my current profile?
Thanks!
- mdgm-ntgrFeb 23, 2017NETGEAR Employee Retired
If you PM me some more details perhaps we could do a profile merge.
