achatter01
Feb 15, 2017Aspirant
ReadyNAS NV+ power supply
I have a ReadyNAS NV+ that I purchased long back 2007/2008 timeframe. It has worked excellently thus far, but yesterday I powered down from the admin panel and today when I tried to power up, it is s...
Sandshark
Feb 19, 2017Sensei
Do a search on "legacy power supply" and you'll find a post by me about changing the pin-out on a standard Flex ATX supply. One caution not covered there, because I did not know they existed and the thread is now closed, do not use a supply with two +12V busses. You cannot safely just tie them together.
- achatter01Feb 21, 2017Aspirant
Thanks for the pointers. Not very confident of changing pin-outs on an existing power supply. Are there some videos/instructions for doing that?
Thanks again!
- SandsharkFeb 22, 2017Sensei
I didn't think to make a video or take pictures when I did it. But you might find generic videos on pulling the pins on an ATX connector. Pulling the pins is the hard part unless you purchase a tool for that (which is pretty cheap on eBay). You could cut and splice instead of pulling pins. If the supply doesn't have the 4-pin CPU power connector and you have to use the drive connector wires for the additojnal 12V, that's about the only way to do it, anyway.
