achatter01
Feb 15, 2017Aspirant
ReadyNAS NV+ power supply
I have a ReadyNAS NV+ that I purchased long back 2007/2008 timeframe. It has worked excellently thus far, but yesterday I powered down from the admin panel and today when I tried to power up, it is s...
achatter01
Feb 21, 2017Aspirant
Thanks for the pointers. Not very confident of changing pin-outs on an existing power supply. Are there some videos/instructions for doing that?
Thanks again!
Sandshark
Feb 22, 2017Sensei
I didn't think to make a video or take pictures when I did it. But you might find generic videos on pulling the pins on an ATX connector. Pulling the pins is the hard part unless you purchase a tool for that (which is pretty cheap on eBay). You could cut and splice instead of pulling pins. If the supply doesn't have the 4-pin CPU power connector and you have to use the drive connector wires for the additojnal 12V, that's about the only way to do it, anyway.
