sasqld
Oct 02, 2018Follower
ReadyNAS NV+ RND4000 Upgrade
Hi Support Community
My NAS drive is coming to the end of its life, 2 HDD and a power supply replaced over the last 5 years and i feel its time to retire this unit.
The unit is still operational and my question is which model to replace it with and can my current 4 x 2TB drives be simply inserted into new unit.
3.4TB of 7.4TB currently used so plenty of space.
Regards Tony
- Marc_VNETGEAR Employee Retired
Hi sasqld
Welcome to the Community!
Your NV+ is a bit old and I agree that it might be the time to get a replacement. If you plan to upgrade your unit any ReadyNAS OS 6 4 Bay unit or up will be fit for you.
Your disks and data can be migrated to these OS 6 units but in some cases it will be needing Data recovery service from NETGEAR Support.
RN424 or RN524 might be a good choice as a replacement and since your NV+ is still running you can still use it for backup.
Hope this helps!
Regards
Actually the data can't be migrated, the title of that KB article is misleading. The disks can be temporarily mounted in the OS 6 system, but you then need to off-load the data to other storage. After that you set up the new NAS, which reformats the disks and destroys all the data on them. This service is really to help out folks with failed NAS - in your case the NV+ is working, so you don't need it.
Personally I'd start off the replacement with new disks - fewer but larger ones, and leave some empty slots for growth later on. For instance, 2x6TB. Then continue to use the NV+ to back up the OS 6 NAS as long as it lasts.
