sparky3366
Oct 23, 2019Aspirant
ReadyNAS NV+ RND4000 v2 corrupt boot and a newbie
Hi folks,newbie alert... Ive just been given an ReadyNAS NV+ RND4000 v2 and the raidar software is telling me I have a corrupt boot. The unit has 2x seagate 2TB drives plus 2 empty bays. The drives d...
- Oct 23, 2019
sparky3366 wrote:
It's definitely a v2 with external power pack...
thanks😊
Great. The factory default through the boot menu is described on pages 24-25 here: http://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_en_23-Mar-12.pdf
Another way to proceed is to zero the drives (or unformat them), and then insert them into the NAS and power it up. That will automatically do a factory install.
Oct 23, 2019Guru - Experienced User
What you need to do is a factory default procedure from the boot menu. That will reformat the disks and install the operating system on them.
But the procedure for doing that does depend a bit on whether you have an NV+ or an NV+ v2. Although you say you have a v2, many NV+ owners mistakenly think they have a v2. That's because the labeling is confusing.
An NV+
- runs 4.1.x firmware
- says NV+ on the front chassis
- has an internal power supply
An NV+ v2
- runs 5.3.x firmware
- says NV+ v2 on the front chassis
- uses an external power brick
Once we know for sure what you have, we can direct you to the correct boot menu procedure.
sparky3366 wrote:
When I try to run RAIDiator after unzipping from the netgear site, there isnt a usable file format...im bing told that.13 isnt a usable file format.
RAIDiator refers to the firmware that runs on the NAS. You don't run it on the PC.
sparky3366 wrote:
...trouble is I'm now blind. I can still do most things but this is all new to me.
You likely will need help from someone sighted in order to use the NAS boot menu. Unfortunately you might also need help with the ReadyNAS web interface, as it isn't designed to be accessible.
sparky3366
thanks😊
- StephenBOct 23, 2019Guru - Experienced User
thanks😊
- sparky3366Oct 23, 2019Aspirant
We have lift off!!! Thank you very much for your assistance for this newbie...really appreciate it 😊
I'm glad I was able to help.
