wb26
Feb 04, 2025Star
ReadyNAS NV rnv1-s2-0000 can’t connect
Hello everyone- my old ReadyNAS NV (Infrant Ready label) powers up, I can ping it successfully but cannot access the files on the drives. Tried remapping the drives in file manager but the connection...
Feb 04, 2025Guru - Experienced User
wb26 wrote:
If all else fails can I buy an old chassis and put the drives in there to recover my data or is there another method I can use to recover the data?
Any guidance on troubleshooting is greatly appreciated. Thank you.
Have you tried RAIDar? It might give you more information.
I suggest testing the disks in a Windows PC with vendor tools (Seatools for Seagate, Dashboard for Western Digital). Run the short test first, if that passes then run the long test. You can connect the disks with a USB adapter/dock.
There are of course other possibilities, including a memory failure.
As far as recovery goes, you could also get a 4-bay enclosure and use R-Studio (or similar RAID recovery software) to recover data.
You'd need the $79.99 license.
wb26 wrote:
I also can’t access the NAS web interface.
What error are you getting?
- SandsharkFeb 04, 2025Sensei
How does it behave and what does RAIDar indicate with the drives removed?
- wb26Feb 04, 2025StarRAIDar does not work on my windows 10 system. I also tried running RAIDar in windows 7 compatibility mode but no luck. Is there a version that is compatible with windows 10?
Will R-Studio work if I configured the NAS as X-RAID?
When I try to access the admin interface at http://192.168.1.80/admin I get a can’t reach this page error even though the can ping the address successfully.
Any idea what the blinking power LED indicates?
Once on, the NAS is also difficult to power down. Only way I can power down is to hold the powering button down for about one minute.
Thanks- SandsharkFeb 04, 2025Sensei
I'm running RAIDar on Windows 10 and 11, so it is compatible. You do need a compatible version of Java installed.
RAIDar is how you find out the status of your NAS. Your description doesn't sound like any of the documented LED error codes. But those are listed as being for 2-drive systems (after the NV was replace4d by the NV+, the only units without a display):
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by a 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code. Current error codes: 1 - Vendor mismatch 2 - No disks detected 3 - Bad contents on root partition of disks 4 - Flash error 5 - Unsupported RAID configuration- wb26Feb 04, 2025StarThat must be it. I do not have Java on this laptop. Do you know which version of Java is required?
- StephenBFeb 05, 2025Guru - Experienced User
wb26 wrote:
Will R-Studio work if I configured the NAS as X-RAID?Yes. Do you know what firmware the NAS is running?
- SandsharkFeb 05, 2025Sensei
If you choose to get another NAS for your volume, you can also use an NV+ (the original, silver one, not the V2 black one). But before you do that, lets make sure it's the chassis, not the volume, that's the problem. What RAIDar sees with no drives will go a long way to determine that.
