wb26
Feb 04, 2025Star
ReadyNAS NV rnv1-s2-0000 can’t connect
Hello everyone- my old ReadyNAS NV (Infrant Ready label) powers up, I can ping it successfully but cannot access the files on the drives. Tried remapping the drives in file manager but the connection...
Feb 04, 2025Guru - Experienced User
wb26 wrote:
If all else fails can I buy an old chassis and put the drives in there to recover my data or is there another method I can use to recover the data?
Any guidance on troubleshooting is greatly appreciated. Thank you.
Have you tried RAIDar? It might give you more information.
I suggest testing the disks in a Windows PC with vendor tools (Seatools for Seagate, Dashboard for Western Digital). Run the short test first, if that passes then run the long test. You can connect the disks with a USB adapter/dock.
There are of course other possibilities, including a memory failure.
As far as recovery goes, you could also get a 4-bay enclosure and use R-Studio (or similar RAID recovery software) to recover data.
You'd need the $79.99 license.
wb26 wrote:
I also can’t access the NAS web interface.
What error are you getting?
wb26
Feb 04, 2025Star
RAIDar does not work on my windows 10 system. I also tried running RAIDar in windows 7 compatibility mode but no luck. Is there a version that is compatible with windows 10?
Will R-Studio work if I configured the NAS as X-RAID?
When I try to access the admin interface at http://192.168.1.80/admin I get a can’t reach this page error even though the can ping the address successfully.
Any idea what the blinking power LED indicates?
Once on, the NAS is also difficult to power down. Only way I can power down is to hold the powering button down for about one minute.
Thanks
Thanks
