wb26
Feb 04, 2025Star
ReadyNAS NV rnv1-s2-0000 can’t connect
Hello everyone- my old ReadyNAS NV (Infrant Ready label) powers up, I can ping it successfully but cannot access the files on the drives. Tried remapping the drives in file manager but the connection...
wb26
Feb 04, 2025Star
RAIDar does not work on my windows 10 system. I also tried running RAIDar in windows 7 compatibility mode but no luck. Is there a version that is compatible with windows 10?
Will R-Studio work if I configured the NAS as X-RAID?
When I try to access the admin interface at http://192.168.1.80/admin I get a can’t reach this page error even though the can ping the address successfully.
Any idea what the blinking power LED indicates?
Once on, the NAS is also difficult to power down. Only way I can power down is to hold the powering button down for about one minute.
Thanks
Thanks
Sandshark
Feb 04, 2025Sensei
I'm running RAIDar on Windows 10 and 11, so it is compatible. You do need a compatible version of Java installed.
RAIDar is how you find out the status of your NAS. Your description doesn't sound like any of the documented LED error codes. But those are listed as being for 2-drive systems (after the NV was replace4d by the NV+, the only units without a display):
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by a
1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configurationRelated Content
