wb26
Feb 04, 2025Star
ReadyNAS NV rnv1-s2-0000 can’t connect
Hello everyone- my old ReadyNAS NV (Infrant Ready label) powers up, I can ping it successfully but cannot access the files on the drives. Tried remapping the drives in file manager but the connection...
Sandshark
Feb 04, 2025Sensei
I'm running RAIDar on Windows 10 and 11, so it is compatible. You do need a compatible version of Java installed.
RAIDar is how you find out the status of your NAS. Your description doesn't sound like any of the documented LED error codes. But those are listed as being for 2-drive systems (after the NV was replace4d by the NV+, the only units without a display):
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by a
1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configurationwb26
Feb 04, 2025Star
Installed Java 8 update 441 but no luck running RAIDar 4.3.8. I can’t even uninstall version 4.3.8.
I tried redownloading and reinstalling 4.3.8 but get an immediate error of “The application was unable to start correctly” This is the same error I get when I try to run the already installed copy of RAIDar 4.3.8.
I downloaded version 6.5 which runs but fails to detect the NAS on my network. I can ping the NAS successfully from the PC I’m running RAIDar 6.5 on. Does version 6.5 support the ReadyNAS NV?
