wb26
Feb 04, 2025Star
ReadyNAS NV rnv1-s2-0000 can’t connect
Hello everyone- my old ReadyNAS NV (Infrant Ready label) powers up, I can ping it successfully but cannot access the files on the drives. Tried remapping the drives in file manager but the connection...
Feb 10, 2025Guru - Experienced User
wb26 wrote:
Any ideas on what I can try next?
You could try tech support mode. Have you ever used the linux command line interface?
Also, you could power down and test the disks in a Windows PC with vendor tools.
wb26
Feb 10, 2025Star
Yes, I have access to a linux box but I’m not familiar with tech support mode. Please forward any info you may have.
The original drives are Seagate part number 9bl13e-301 250GB. I’ll check what tools they offer. I also have a licensed copy of SpinRite by Gibson Research that may help check data integrity.
Thanks for your help, really appreciate it.
