clearlink
Sep 19, 2024Aspirant
Readynas NV+, stuck in FS 35%
The NAS has four disks, disk 1&2 (volume 1) disk 3&4 (volume 2). Disk 2 failed so I replaced it with the same disk, Seagate ST31000528AS. Upon insertion of disk 2, it starts to check the file system ...
clearlink
Sep 20, 2024Aspirant
Hi, thank you for the reply. I also thought that the disk might be bad so I checked it with Seatools and it came back good. I know the drive is old, but supposedly this was old new stock. I have other 1TB drives on hand, like the WD10EZRX to try.
Sep 20, 2024Guru - Experienced User
FWIW, I run the long (non-destructive) test, followed by the full erase test. That is because I have had some out-of-the-box drives that passed one of these two tests, but failed the other.
- clearlinkSep 22, 2024Aspirant
I gave up on the seagate and installed a WD 1TB drive. Now on the raidar the WD shows up with a + inside the icon, which supposedly means the drive is labeled as spare but it did not mount it to the original 2 drive Raid 1 setup. I don't see a way to add it.
- StephenBSep 23, 2024Guru - Experienced User
What are you seeing in frontview?
- clearlinkSep 23, 2024Aspirant
Front view shows the drive with a red cross in the circle icon. It also displays that resynch is queued but stay that way for days. Disk 2 led in front keeps blinking away.
