EricBlantz
Feb 25, 2019Aspirant
ReadyNAS NV+ upgrade after PSU failure
I've had a ReadyNAS NV+ (RND4000) since it was an Infrant product (est. purchase 2005?). Except for a PSU failure several years back, which I replaced, it's been rock solid. Given it's age, I've been considering an upgrade for a while, but now the PSU appears to have gone out again, or at least I'm hoping it's that simple. My question is whether I need to repair the PSU on a very old unit in order to migrate to another NAS device and, if not, can I simply swap the discs (3x 750Gb Seagate) into a new ReadyNAS device? What are my options for getting my data off the drives if I decide NOT to stay with Netgear/ReadyNAS? Thanks in advance.
- EricBlantzAspirant
Sorry about the last subject/title. I have no idea how that was entered. My issue is related to NV+ upgrade and data migration options.
I took the liberty of fixing the title on the first post.
It is possible to replace the PSU. The pinout isn't standard, so if you use an off-the-shelf PSU you'll need to modify it. The wiring changes are described here: https://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
There are some folks out there who are selling turnkey PSUs (already modified), but they are quite expensive. There are also some used NV+ out there, so you could purchase one with a working PSU and swap that over.
If you have an ATX supply, you can jury-rig something that will work temporarily - using extension cables to connect the PSU to the NAS. You can modify the pinout in the extension cable.
If you buy a new ReadyNAS, you can use paid support to temporarily mount your disks in the new NAS. That would let you off-load the data. However, this can be pretty expensive. https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
If you can connect the disks to a PC (either with SATA or USB) you can either
- boot the system under linux, and manually mount the RAID array or
- use RAID recovery software (R-Studio is reasonably priced). https://www.r-studio.com/
Thanks for the reply and the fix, StephenB. Revealing my ignorance here but... re the new NAS option, wouldn't my disks old just mount, and then I could backup to another device before upgrading to next/larger disks? or is there something proprietary about the RAID used in the NV+?
