SAMBASANCHEZ
Oct 04, 2020Follower
ReadyNAS NV+ V1 Not powering on
Hi Netgear Community, I have a Ready NAS that just quit working on me. I have reasearched online and it seems the PSU is out. This unit is obviously old, but it was working with no problems. I w...
Oct 05, 2020Guru - Experienced User
It is possible to replace it, but if you use an off-the-shelf supply you need to make a modification in the cable. I've attached a pdf showing the wiring.
There are a couple out there on ebay and other sites that already have the wiring change (at least the sellers say they do). The Netgear part was RND4PSU1-10000S (part number was 332-10384-01).
Sandshark
Oct 05, 2020Sensei
If you have decided that it6's time to upgrade, anyway, you can also make an adapter cable to go from a standard ATX supply to the NAS, swapping/removing pins per the drawing StephenB attached. You can mount that externally and allow you to download the files to your new NAS or a backup device. Just use masking tape or similar to cover the gap the cable runs through in the back so as to keep the airflow right for the drives.
