Shane88
Jan 20, 2022Aspirant
readynas nv+ v2 Access After Changing Router
Hey. Was hoping someone could help me understand this. I can no longer access, read or modify my RND4000v2 after switching routers due to my old router dying. The READYNAS NV+ v2 is curr...
- Jan 21, 2022
Shane88 wrote:
Hey.
The READYNAS NV+ v2 is currently displaying 192.128.1.1 i logged into my new router and switched the IP to match but that did not give me access.
192.168.1.1 is likely the IP address of your router, which would create a duplicate address.
Try doing an OS reinstall on the NAS - see pages 24-25: https://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_en_23-Mar-12.pdf Be careful not to accidently do a factory default.
The reinstall will reset the NAS to use DCHP, and also reset the admin password back to password.
Is this a typo? Or did you mean 192.168.1.1?
Jan 21, 2022Guru - Experienced User
Shane88 wrote:
Hey.
- Shane88Jan 21, 2022Aspirant
Yes sorry that was a typo.
Readynas is displaying 192.168.1.1
My current i.p is 192.168.0.1
I logged into my router and changed it to match the readynas but was still not able to read or access the admin page.
- StephenBJan 21, 2022Guru - Experienced User
Not surprising, since 192.168.0.x and 192.168.1.x are different subnets. Changing the router IP to 192,168.1.1 puts them on the same subnet, but gives you a duplicate address (both the NAS and the router are assigned to 192.168.1.1).
Do the OS reinstall. Then if you need a persistant IP address for the NAS, reserve it in the router.
