thaiZilla
Apr 05, 2020Aspirant
Readynas NV+ v2 cannot map network
Hi All I've had my ReadyNas NV+2 for 6 years. I've had it working on and off over these years, but the last 2, since using Windows 10, i am able to view and access the storage, however i cannot m...
thaiZilla
I have just tried this solution and this doesn't work for me either
- SandsharkApr 05, 2020Sensei
On my network, using the NAS name in Windows 10 is hit-or-miss, while using the NAS IP always works. Have you tried doing the mapping using the IP address instead of the NAS name?
If that works and you still want to be able to use the name, you can add the IP address to the hosts file. Of course, both of these rely on the NAS having a fixed IP address, which is best done by reserving one in the router, not by using the NAS static IP setting.
- thaiZillaApr 06, 2020AspirantHi Sandshark
Thanks for the response. I have been using the ip using the following format
\\ip/C
Still not working. This has only ever happened since moving to Windows 10. I can see the nas drive Via Network and view the documents but i can not add or delete to them. I use to map the network and input my username and password to edit add or delete files. Now i can only view them on the network but even that, is a stripped back version of all my data on the NAS drive.
Thanks
Coe- StephenBApr 06, 2020Guru - Experienced User
thaiZilla wrote:
\\ip/CThe correct syntax is \\ip\C
But there likely is a credentials issue here. You can only access C if Windows is using the NAS admin credentials.
Try running CMD (type it in the search bar) and enter
net use * /delete /y net use t: \\nas-ip-address\C /user:admin nas-admin-password
The first command disconnects any open SMB sessions, the second attempts to mount the data volume as drive letter T.
BTW, this won't work if the NAS is using the default admin password.
