TheDrSavage
Feb 29, 2016Aspirant
ReadyNAS NV+ V2 Hard drive set up
Hi Bit of a newbie question, Sorry. I ReadyNAS NV+ V2, Got 2x2tb 2x4tb WD NAS red Drives. Want 2x2tb mirrored for photo, music and home videos, for secure back up. So mirror 1 Then 2x...
TheDrSavage
Thanks StephenB, thats exactly want I needed. Will set it off again.
TheDrSavage
Mar 02, 2016Aspirant
Hi,
ok ok after a few attempts, still can't mix raid 1 on 2 x2tb with JBOD on 2x4tb. The nas makes both sets raid 1, so 2x2tb is c: raid 1 and 2x4tb is d: raid 1.
tried to put all as JBOD, but it did exactly the same thing, so did a format, good thing I was on nights, it took 2 night shifts and sleeps during the day.
i can get both 2TB to raid but can't get 4TBs to stand alone.
cant see in the dashboard where to format 1x4TB after creating 2x2tb raid 1.
any idea ?
Thanks
- TheDrSavageMar 02, 2016Aspirant
I don't think I can mix Raid 1 and JBOD, as page 22 of manual says
disk installed 2 then raid 1, disks added 2 another raid 1 created.
you can't create a raid 1 after selecting JBOD at set up
- StephenBMar 02, 2016Guru - Experienced User
That's quite annoying. You can do that with all the other ReadyNAS (but I don't have a V2, ...). Perhaps another v2 owner (or Netgear) can clarify.
- TheDrSavageMar 03, 2016Aspirant
Can you tell me how you do it in your setup ?
ive rebuilt it as 4 JBOD disks, but can't see how you could change the 2x2tb drives to raid 1, as you can't get set up to run again without undoing the current set up and it detecting 2 sets of matching drives and making them raid 1 for each set, plus there doesn't seem to be any option in the dashboard to click and create the drives as raid 1.
it would be a shame if you can't mix raid with JBOD ?
