wheelhouse20
Mar 17, 2019Aspirant
ReadyNAS NV+ V2 HDD Locked
hello my nas has locked all 3 of my hard drives. could some one help me unlock them?
thanks Paul
Will276
Jun 08, 2019Aspirant
ReadyNas Duo V2
I think I have the same issue, if someone could help me I would be massively grateful.
TIA
Jun 09, 2019Guru - Experienced User
Try doing a factory default using the boot menu (with only one of the locked drives installed).
Are you certain you have a v2? Many v1 owners mistakenly think they have a v2.
A Duo v2 will say "v2" on the front of the chassis, and runs 5.3.x firmware. If you do have a v2, the instuctions for doing the factory default are on pages 16-17 here: http://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_en_23-Mar-12.pdf
